shagman505
5
So I just got done rebuilding a bottom end on a kx250. This is the second one I've done, but I still feel like such a genius/god/hero when I do one. Sure, it's not that big of a deal, but after all the mechanical mishaps that I've been a part of it's nice to have a success. This got me thinking about mistakes I've made in my few (I'm 18) years of working on motorcycles. Putting the piston in backwards, siezing top ends after changing jetting, having chains jump due to improper adjustment, etc..... I figured all of you out there must have some stories of your own you could share about your mechanical mishaps. Oh, and don't try to lie and say it was "your friend" or "your neighbor" and not you....we'll see right through it ;)
Highbeam
662
It seems every time I put in a new truck engine I get the stupid distributor in 180 degrees off so no sparky at the right time depsite lining up the timing marks.
On the motorcycles, xr200s, I seemed to have no problem getting the timing chain a link or two off and blowing the head gasket.
Moto Squid
853
the former owner to my old snowmobile did a top end...one old piston circlip went flying but he couldn't find it and said screw it. Turns out it ended up in the crank. Lets just say I bought the thing real cheap
My favorite is this 300ex we have at work right now. The guy and his buddy did a top end but totally scewed up on cam chain tensioner position when reintalling and just jamed it in. Chain stretched, skipped a few teeth and the valves nailed the piston. That was pretty cool :laugh:
My mishaps are far less spectacular...especially now that I'm a little older.
gwcrim
1,881
Circlips... yeah.
I lost one down into the case on my old CR125. Had to remove the engine and shake it out.
I didn't do the 180 out but wired the distributor backwards on a 383 Mopar. Even tried to start it by pulling it. Man were my buddies pi$$ed when we figured out what was wrong.
Heh.... then there was the old 383 I rebuild and put the bearing caps on backwards..... It lasted, oh..... 5 miles maybe?
That was all when I was in high school. I quit rebuilding engines for a few years until I figured out WTF was going on.
yam 3
248
An 89 yz250 is able to be assembled with first and third gear swapped. Tranny will work also. Luckily I caught it before it went back in the bike!
Y2Z
411
lol yam! luckily i have never had anything serious go wrong with rebuilding bikes. but i did spend an hour and a half trying to figure out why the rings wouldnt go on the new piston for my 89 KDX. drove out about an hour to the local kawasaki dealer and turned out i had them in upside down! i didnt know it made a difference. stupid me
rickyd
Hot Sauce
Oct 28, 2001
3,447
I was wrenching on a 650sx (jet ski) and had too do a leak down test on it.. After doing the test, went too start it and couldn't get it too fire.. Scratching my head, realized i forgot too take out the plug ant the reed cage :laugh:
jboomer
1,420
I raced once and was doing well until about the end of the 2nd lap (5 lap race). Every time I jumped, the bike would die so when I landed it would start the engine again, almost throwing me over the bars. I even crashed once when I hit the face of the jump, the bike died, causing me to land nose low on the face of the landing ramp. Well, after struggling through the race, I finished dead last. It was really rainy that night and the track was extremely muddy, so I didn't even bother doing a bike inspection until the next morning. Went outside and searched the bike, but couldn't find the problem. So, took the bike out of the truck and when I turned on the gas, gas started POURING out of the bike. Well, traced the fuel stream to the drain bolt on my carb. Turns out, before the race I put in a larger main jet (so the bike wouldn't get too hot) and finger tightened the drain bolt, but I guess I forgot to tighten it with a wrench. Everytime I would jump I guess the carb would raise up a few milimeters allowing the gas to drain out of that little hole on the side of the drain bolt and drain my float bowl. On the big jumps, there would be enough zero "G" to cause the bike to bog, then die.
splatt
Resident mental case
908
16
It's a wonder you got it to turn over. Most of the time it won't. I've been profesionally rebuilding car and truck engines for 12 years now and there are still those times those bonehead mistakes come up.
Steve
Yogurt
218
Once after installing a brand new wiseco piston and top-end in my 00 CR125, I started it up and ran it at idle, then after about 1 minute it blew up and died. Oh crap I thought! I immediately tore it all back down, and realized it sucked the circlip right out, and ran it up and down the cylinder walls real nicely. I put the circlip in all the way, but I forgot to turn the circlip so the end wouldn't be sticking up in the groove. So I had to send my cylinder out to US Chrome to have it replated, cuz it had deep gouges in the walls. I took the whole motor out, and flushed out the lower end with parts cleaner, and tipped it upside down to get the circlip pieces out. Then I had to buy another top-end kit. That was one expesive top-end job I did. I really hate doing things twice.
Danman
2,208
Were is Moo Cow when you need him (anyone remember that name) :) I wouldn't know any stories as I've never done anything boneheaded thing while working on a bike :confused:
jmics19067
2,097
Just not enough web space to list mine but my all time favorite is
while trying to figure out why a bike won't start I always check for spark, You know, remove the spark plug , lay it against the head turn it over, get a new plug, put it in the cap lay it against the head turn engine over, good spark , install plug kick till blue in the face and realized I didn't put the plug cap back on the plug.
gwcrim
1,881
Oh here's another one.....
I had a partner on a Bonneville Salt Flats speed racer. He supplied me with a 100" Sporster engine in which he had invested many, many thousands of dollars. I had to install the primary drive. But I'd never done one before. After struggling with a pile of parts and the repair book, I got it all bolted together. We first fired the engine on Friday and left from Ohio on Saturday for dyno tuning in Denver with Aaron Wilson.
After several dyno pulls, we pull the clutch cover to for an inspection and it's overflowing with oil! So we pull the primary drain plug and the magnet is FULL of stuff. I about poohed in my pants.:uh:
We pulled the cover an upon inspection....... I had left out a spacer that fits between the front sprocket/alternator cover and the crank shaft. This allowed engine oil to fill the primary. This also allowed the crank to have an in/out movement of about 1/8". This destroyed the stator and the alternator magnets. Again, I about poohed my pants.:uh:
We pillaged a spacer from a Buell donor bike in Aaron's shop, cleaned up the mess, and reassembled. The bike eventually dyno'd about 150 HP. A bit lower than what we expected but at least it was alive. We managed to get the bike to 167 and set two records. Come to find out the pistons & cylinders were scored as well.
Eventually got the bike to go 180 with a good top end.
Oh and then we're at the Flats and the cable that activated the remote petcock got pinched. The result was that it might shut at any inopportune moment. So there I am buzzing along at speed with one hand on the throttle and the other holding the petcock open. Good thing it was on the left side. Again, I about poohed my pants. ;)
JasonJ
1,150
My first 4 stroke bike, KLR 250, was hard to start when I bought it. I had to push it all the time. got worse and worse till no vroom vroom. Started tinkering and found the valves were not closing. I discovered the tapet adjusters and just turned em out untill the valves would hold gas in the intake and exhaust ports. Feeler guages? Sure! if she lets me I will! I put it all back together and felt like a hero when the bike started. Ran the bike out in the field with a big smile, then, the most gut wrecnching mechanical sound I ever herd as the nut on the tapet I forgot to adjust got into the timing chain and caused it to break shattering the valve cover and bending the crank among other things ..... No more KLR :( .
I spent 4.5 hours installing a new set of front leaf springs in a truck wich was a good time for the job. Some one esle had taken the springs out to get the measurements. I put the new ones in and go to drive the truck out, turn left out of the bay, then right,,,, the wheel dose not turn right more than 1/4 way! Back the truck back in and start looking it over, takes me aoubt 10 mins to relize they had an offset center pin and I put them in backwards! The 4.5 hour job went to 6 hours. Dohhhhh!
Oh another good one, Had a flat on my bike as a youth, so I fixed it and rode it to school the next day. On the way home to show off to all the kids I yank a big ole wheelie on the way out the lot, how surprised I am to see my front wheel keep going, forks come down, hit the pavment, I go over the bars in a heap. It hurt, but I was so embarassed. I looked up and OMG! No one had seen it! I hobbled over to the bike and collected the front wheel and hobbled around the corner to agonise in pain :p .
Other than that, just dumb stuff like putting your front wheel on with the disc on the wrong side :)
motometal
2,680
When I had my first 6 or 8 bikes, I was on a very tight budget.  These were bikes that were bought for $5-$100.  I don't remember ever even buying a gasket.  On one particular '74 Suzuki TM125, I remember immediately taking the top end apart because it supposedly had a race ported engine and I had to see what this was all about (of course otherwise nothing was wrong with it).
Using silicone as a base gasket, after re-assembling it I started it up and rode about 300 yards until it seized up.  This was because the bike was oil injected, and the cylinder base had a tiny hole for the oil to go through (which I sealed up nicely with the silicone). :|  I put on another cylinder, but that race porting on the wrecked one musta been pretty good, because the bike never ran quite the same again.
FTR John
Drive an hour and a half to go riding one more with my buddy we get there and his bike won't start, I do a quick blast around the area maybe 20 minutes and come back and he is all loaded up screaming and ready to go...we had very limited tools with us.....Get all the way back home and I ask him, did you take your pipe plug out?.....should have seen the look on his face.
However in that time he had his carb off put a new plug in and also checked to make sure he did not leave a rag in his air box.
The infamous Tootsie Roll wrapper.
Once upon a time, way back in 19, ahhhhhh, er, ahh, never mind. :eek:
I was doing a rebuild on my dirttracker and had the bottom end done and back in the frame. It was late at night and I had a race the next day and all I had left to do was assemble the top end.
My wife came out to the shop and said something like, " are you coming in tonight or what?" I said, just as soon as I get the bike together.
She was eating one of those minature Tootsie Rolls at the time and as she turned around to go back in the house, she wadded up the wrapper and tossed it at me. As luck would have it, the wrapper bounced off of my forehead and went right down into the lower end of the engine. :scream:
The engine was a 750cc Triumph twin with a big heavy flywheel. The Tootsie Roll wrapper went all the way down into the bottom end and stuck in the oil under the flywheel. Well, seeing as how Tootsie Roll wrappers are made of paper, I couldn't use a magnet to retreive it and there was not enough room to get any kind of device under the crank. Tried some air pressure and only succeded in blowing oil all over the frame and myself but, no Tootsie Roll wrapper. :(
Wound up having to remove the engine cases from the frame and turning the engine upside down and flushing the wrapper out. My wife, seeing my displeasure, had long since gone in the house and went to bed.
Finished the bike at about 0 two early in the morning and made the race the next day. We still chuckle about the infamous Tootsie Roll wrapper. :laugh:
bclapham
4,340
ive just got done with some butchery- i am swapping the clutch basket on my RM, the old basket is servicable and would have made somone a nice spare- anyhow, i center punched the rivets but a couple were off center- i went to work with the drill press and of course some of the holes went off center and drilled into the soft alum of the basket- i am even madder with myself since the drill bit bending has even elongated a couple of the holes on the backing plate.
and then there was the time i used a screwdriver to remove a crank seal- of course it sliped and gouged the cases and i had to email OL89r and tell him of my incompetance!- i used JB on the little gouge and all is well.
so there it is, i am a true Hack!
elf
695
Hmmmm.... I have alot of storys. I am not known for my mechanical prowess. But the best one has to be when my son and his friend decided to put new top ends on their 125 yzs. They were working on both bikes at the same time. I was working on my bike and helping out when needed.
After the bikes were done we went riding. after a couple of laps I saw them sitting on the side of the track looking down at their motors. I rode over and asked them what was wrong? Our bikes seized. Both of them? yep.
So we drove home and tore the bikes apart. both bikes had a piston pin clip come out. Both cylinders had to be re-plated. Anyway it was real weird that both bikes seized at almost the exact same time.
osheen
202
When I was about 12, I put a new piston & rings in my Kaw 90. After some frustration I got it back together but it didn't have any compression. I took the cylinder off to find the rings had been broken into several pieces. I was more careful the second time.
About the same time I was given a minibike with an ohv honda 55 engine. I rebuilt the whole engine but it just never ran worth beans. It seemed to froth a lot of fuel back through the carb too. I junked it after a while. A few years later after becoming a little wiser about 4 strokes I realized I never timed the cam!
KawieKX125
946
I did a crank on my 01 KX125 in a day in order to get it ready to ride for the race the next day, I started the bike up at about 12am and it ran for a couple revs and instantly siezed. I started to tear it down and remembered forgetting to tighten the primary nut, a new nut and an hour or so later after recentering the crank in the bearings I was back in business. I am back in the cases again now though because the crank I just did is shot after 8 months, oh the joys of riding a 125 WFO all the time.
On my 96 KX125, first top end I ever did at about 12 years old, I forgot to reinstall the pipe because I was so anxious to start it and fired it up without a pipe, didnt do any damage but it sure ran weird.
I have done the circlip drop many times but usually I can snake em out with a magnet.
Originally posted by KawieKX125
I have done the circlip drop many times but usually I can snake em out with a magnet. [/B]
It's always fun to lay an old circlip on the bench when your buddy has just reinstalled his top end and then say, where's this go?:eek: :confused: :scream: :laugh: :laugh:
Can Can Kev
233
ill have the spark plug out of my bike for whatever reason, leave come back and i go to kick it over, and i about crap my pants because there is no compression i look down theres no spark plug and i feel so stuipid i could kill myself, *in a homer voice** DOH!
