ChadInColo
- Feb 14, 2005
- 26
- 0
I need help, trying to change the rear sprocket on an old YZ80, the axle bolt appears to be frozen to the bearings. I've tried tapping on the bolt, wouldn't loosen it. I've been spraying penetrating oil under the seals to try to get it into the bearing/axle joint, but obviously can't see what's going on. Any ideas? I may have to cut the bolt (inside the swing arm) so I can get the wheel off, then press the bolt out.
