Here Goes
Bike has done 20 hours just had new piston and gearbox oil.
Heard a crunching grinding noise while on the track got to the point where the bike stopped, had to kick harder than normal the gear lever into neutral.
The bike will start fine and rev no problem so not a motor issue.
Put bike on stand warmed it up and engaged the gears with no issue but the back wheel will not spin at the speed you would expect for the gear and is very judderly, more than usual.
pulled clutch in but made no difference wheel still spun but again like it was actually engaged, applied brake pressure and pulled clutch in, removed brake pressure with clutch pulled in but still spun up juddering.
Gearbox oil clean and at correct level. no water has been added to coolant.
Very confused and obviously gutted.
Any advice will be appreciated! Thanks
