WildBill said:![]()
She may be old, but she's never let me down! :ride:
m0rie said:Funny...Thats what I say about my 89! ;-)
You gotta get a pipe (or do the pipe mod) and some kx suspenders
on that bad boy. You'd be amazed at the difference...
Smily said:I ride a 93 kdx 200, what is a kx suspenders?
Very Nice green. How do you like your CEK? Did it make your bike faster?Green Hornet said:![]()
2005 KDX220R, FMF Gnarly Rev Pipe, TBC2 Silencer/SA, VF3 Reed Valve, Wiseco Piston, RB Designs Modified Head (Squish Band Cut for more compression), RB Designs Modified Carb (33mm bored to 36-Divider Plate installed on intake side of carb-Slide cut from #5 to #7-leaner, CEK Needle Installed, Pilot Circut Mod/Jetting Adjustments, Float Bowl Allen Bolts & Thumb Air Screw), Trail Tech Endurance Computer, Renthal KX Aluminum Bend Bars, Pro-Taper/Scotts Grips FRP Solid Upper Bar Clamp & Brush/Bark Busters, Dunlop D756 Rear & Micihelin S12 Front, 2001 KX 250 Front End w/KX Caliper/KX Wheel, Braided Steel Brake Lines, WER Steering Damper, Moose Fender Bag, Moose Skid Plate & Seal Savers.
m0rie said:foots has 49mm showa conventionals from a drz on his kdx.
