Bman007
34
I took the stock light of my 03 KDX220 and put a mx number plate. I wanted to attach 2 small light's to the sides where the reflectors were or attach side by side on the top. Has anyone come across a website that sells small light's. They would have to be 2 15watt to total the 30 watt output so i can use original wiring. Thanks for the help
kmccune
2-Strokes forever
2,726
Try the link below, it is for and ATV with a 35 and 20 W bulb but they look like the ascerbis bulbs, you need to check ( I had an ascerbis headlite on my old YZWR and I used a pencil and a flood type projector bulb at 15 w each, does not turn night into day but gets you home and I never had any problems)
You could also fabicate a black/white or gray PVC housing and use the hardware store bulbs
http://www.denniskirk.com/jsp/produ...K0NKIV0?catId=116&leafCatId=11602&skuId=22355
