I'm trying to determine how far to go in checking out a new-to-me 90 kdx. I'd like to be thorough but not do alot of work for nothing. The history of the bike is it's sat unused for most of it's 15 years with some riding and maintanence every few years. The only mods are aluminum handlebars and removal of the lights and odometer.
The compression is 180 psi with the engine cold.
The oil is milky, so I'm replacing the waterpump seal (and shaft if grooved).
I'm going to pull the head to check/repair the KIPS valve system and inspect the top of the piston and ring.
I'm also going to pull the airbox, carb, and reeds to check/clean as needed.
I've ridden the bike some and the tranny seems fine except it doesn't want to go into neutral when the engine is running. This is with new oil. I'll flush the tranny before riding it again.
Would you go any further in the engine than pulling the head and replacing the waterpump seal? Anything you'd check on the clutch assembly?
