Kawierider
- Jun 7, 2001
- 281
- 0
Hey Guys
Ok, I've removed all the case screws, the clutch and the gear off of the cranck. The Magneto, and flywheel are off as is the cylinder.
The puller is on its way (mine was to narrow...by a 1/4 of and inch).
The parts to rebuild my cranck are in at the dealership. Has anyone split the cases and just let everything rest in the clutch side case? the cranck will ahve to be pressed out of the R-side case right ? I dont see why it wouldnt work. Does anyone else ? Anyone try it.
I would like to avoid dissasembling the shift mechanism if possible, but If i have to I have to.
Thanks guys!
Tim
Thanks guys!
Tim
