TOTALL
143
I need some advise
I just started riding two summers ago and would like to know the easiest way to learn body position,arm position,stand-up riding,and
controling the bike with my lower body. Everybody that is fast is standing up i need to learn this.I ride hair-scarmbles only.Thanks :confused:
crkid
665
this is more of a personal preference. all i can say is keep your knees and elbows bent and pinch the bike with your knees.
dirtbike59
76
i rider with my knees bent and pinching the bike so my arms don't take all the force. i found out that i should stand up so my butt is about 3-4 inches from the seat. it my take a little bit untill you get the endurance to hold it like that for long periods of time. And i like to keep my head so i can see the front light on my bike. good luck find the right way for you. :)
roostinbe
141
basically in order to stand up while you are trying to controll the bike, and accelerate hard requires you to be one with the bike, meening holding on with your legs instead of your arms. Once you are holding on with your legs (predominantly) then you can begin to practice shifting your weight by pivoting at the waste, and the knees, wrather than at the pegs. Thats not to say that your feet should always be still, but you can keep much better control if you can shift your weight without changing your whole hold on the bike. Plus, if you can't then that meens whenever you move around on the bike, your arms have to take all of the load before you can get back ahold of the bike with your legs.
