May 5, 2007
102
Sorry this might be kind of a dum question and i posted a thread about this a while ago,butIve been practisin them a little here and there.And i dont rev it to the limiter but i give it plenty enough to pull out without boggin and it does a little anywa.Its not a miss or jetting problem,i think i may be lettin out on the clutch a little to fast.Any help would be really appreciated thanks.
High Lord Gomer
Poked with Sticks
Sep 26, 1999
11,788
35
Two things...you're probably right that you are letting the clutch out too quickly. The other thing is make sure you "overgrip" the throttle before the start. Most people grab the throttle in a comfortable position but then can't twist it fully. As you ride the throttle twends to slip a little in your hands and you should also re-grip/over-grip the throttle when you let off as you enter turns.
