Just wondering what everybodys tricks are for stiff clutches. Other than new cables What are some other options to help fix a stiff clutch? I ride alot of tight woods and a easy clutch is a good thing? Any ideas?
The various aftermarket cables like terminator (motion pro I think) or some other silly name work real well due to their construction as they don’t tend to act like a spring.
Yes you could increase your leverage with an expensive lever assembly.
But the cheap way of doing exactly the same thing on the other end is lengthen the actuator arm. I put an extra 8-10mm in my kdx arm which helped a lot & actually improved the angle of the cable.
