Peer Lovell said:Try removing all the engine mounting bolts first. Then try and remove it again.
If not, remove the sub frame put the bike on its side, or better still, upside down and cut the bolt on both sides where the bolt passes through the back of the motor. A sawzall with a metal blade helps. If not it doesn't take too long to cut through with a quality blade by hand.
