goldman15
124
I took my rocker arm off today to grease the bearings. When I went to put it back on I realized there is no way to get a torque wrench in to tighten the top nut. So I basically tighted these rocker arm nuts and the main swing arm bolt as tight as I could. It doesn't seem like you can make these bolts to tight since they were super hard to get off. I will buy a torque wrench(have one now but not up to 60 ft lbs) in the next couple of days but I quess I'am looking for someone to say that there are no negative ramifications to over tighting these bolts. Thanks
