longshore58
92
Looking at possibly changing my 1991 KDX-200 with conventional forks over to a set of USD forks from a 1993.
What issues (if any) will I likely encounter with the front wheel/axle/brake caliper mount/etc working out without having problems with the conversion or will it involve major issues with compatability between the two different forks??
THANKS for any advice!
longshore58
92
SS109
310
Hmm, I just bought a '90 and I'm interested in knowing the answer to this as well
sr5bidder
1,463
most people have said that the 93 usd forks are no better than the rsu forks and have gone with the kx conversion that involves the whole front off a kx 125/250.
If you have the clicker adjustment at the bottom of your forks you may want to do the shim stack mod (-2 shims) search it in the forums.
I am going to try this out in the near future
glad2ride
1,071
The 1993 - 1994 KDX200 or a little better 1991 - 1994 KDX250 forks are better than the 1989 - 1992 forks due to the damper rod vs. cartridge technology, besides the characteristics of the USD forks and reduced underhang.
The "shim stack mod" is for 1995+ usually. The forks he has are damper rod style. I wouldn't try it on the USD forks due to how few shims are in it.
Patman
Pantless Wonder
Swapping out the complete front end proved significantly easier in my conversion (XR250 with KX125 fork). Something to keep in mind is the steering stop situation. Some bikes have ears on the sides of the frame head, some have a tab on the back / bottom of the stem, etc... Then you also need to make sure your frame & the new stem are compatible or come up with a stem / triple clamp / bearing solution that solves it. Make sure you understand how what you have and what you want might conflict and work it out before you go to a lot of work & expense. Besides just being easier to do you then don't have a mix of front end parts to deal with when you need replacement parts.
julien_d
1,788
wheel, axle, and caliper are different on the 93-94. Additionally, those forks are only slightly better. Pretty much on par with the 95+ conventionals. Hardly worth the trouble of sourcing a new wheel/caliper.
longshore58
92
thanks......
good advice from all.............I think I'll just leave the old girl like she is after all........
"If it ain't broke,don't fix it"
julien_d
1,788
The emulators work really well from what I understand, and should be quite an improvement. There is quite a bit you can do to your existing forks to make them better.
The best option though is probably a front end conversion from an MX bike. I've seen yz forks, ktm forks, and of course the most popular kx125/250 forks used. You do need the entire front end usually, and it's most likely not bolt on. You have to use the kdx stem with the mx triples, possible machine work there..
I'm working on a set of 93 yz250 forks right now. 43mm USD's, cartridge type with rebound and compression adjustment. I don't know much about them, but I got the complete front end for free sans caliper, and the 94 kdx caliper I have bolts right on. So my only cost is the rebuilding (seals and bushings) and the time to figure out how to mount them up.
What's the story on the 93 USD's? They can be improved probably easier and cheaper than the older conventionals you have. As a base they're on par with the later model KDX conventionals, and there are good upgrades for them as well. I'd probably only consider it if the 93's were somewhere between dirt cheap and free, personally. If you decide to go that route, I'll have some 94 front end parts after I'm done with the yz front end conversion. I should have front the wheel/rotor, and I've got an extra caliper but no MC. Triples, etc.
longshore58
92
I'm pretty much convinced now that I will just put some .35kg springs in her and let it go at that.....
Good luck with the Yama-saki front end project.....sounds pretty interesting for sure.
longshore58
92
you certainly can not beat free forks !
The RaceTech spring rate calculator is miles apart from what Fredette suggests?! (.35kg)
I would have to weigh 89 pounds to use a .35kg rate (using the RaceTech spring rate calculator) !!
With my correct weight....their number comes up to a .426kg rate.
RaceTech calculator:
180 pound rider (without gear)
Type of Riding: Desert / Enduro / Trail
Rider Weight: 180 lbs
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.426 kg/mm (use closest available)
Stock Fork Spring Rate: .304 kg/mm (stock)
http://old.racetech.com/evalving/Sp...=1991&ml=KDX200&formuse=form1&SpringType=Fork
longshore58
92
yep..
oh .......I'm plenty crazy but those numbers were off by a mile.
RaceTech has a .40/.43/.46 combo fork spring.
Part number FRSP 3750K RT FRK SPR 3 RATE KIT .40-.46
Pretty sure that will do the job.
(I'm not sure how you set up the prefered rate (.43kg) you want from the 3 rates available) ?
Now if I could just find a set used somewhere.
longshore58
92
answer my own question........duh.
Part #: FRSP 3750K - RT FRK SPR 3 RATE KIT .40-.46
From the Race Tech intructions:
The triple rate kit takes advantage of the fact that springs "in series" (stacked on top of each other) are softer than the individual springs themselves. The primary (long) spring by itself provides the stiffest rate (.46kg). The addition of a single secondary (short) spring makes the rate softer (.43kg) The addition of a second short spring makes it softer still (.40kg)
Sounds good to me.........
