Is it acceptable to mount U shaped frame bracket of a WER damper to the hole in the frame or is it better to just drill the frame slightly lower. Seems to be quite level even if using the existing frame hole with spacers on arm. I've seen it done both ways. is one way better than the other? How did the rest of you mount yours?
