hi folks-
I'm new here. I just today picked up a well used '96 KDX200 with a Baja Designs kit and current CA license plate. It has a few good bits on it, looks a bit scruffy, seems in fair shape. I thought it would be interesting to post here and ask the experts to give me their opinions.
Bike is fitted with FMF Fatty pipe, not too dented up. MSR spark arrestor that seems hollowed out (loud). Plug is Champion NC4. Stock carb. No airbox lid. Foam filter. One piece billet upper bar clamp. Billet guard on rear disc and on water pump housing. Alloy bars. Acerbis handguards. Acerbis lights. Generic speedo in round chrome housing. O-ring chain in good shape.
I have not looked at the jets yet. Have not inspected the KIPS valve. Have not counted the sprocket teeth yet.
BTW - How can I tell if the reed valves are upgraded, and/or the carb modified?
Bike starts easily cold using choke, smokes a lot, makes the infamous rattle. Riding it, it seems to splutter or blubber - until the main jet kicks in... then it makes a nice hit of power. First gear is short and sputtery, but then it goes pretty well. I ran it thru the gears and it seems fast enough, but not much low end. At a stop, it idles OK for a few secs, then drops down and dies.
Owner says he added too much oil. Normally he runs a semi synthetic at 35:1. He also said the jetting was too rich... try dropping the needle.
Very oily exhaust outlet. Plug looked new but a bit wet/oily after my test ride... clearly the owner had recently put in a new plug.
Clutch feels fine. Maybe slips a bit at high RPM. No wheelies on the throttle. Brakes were fine for a dirt bike. Suspension went up and down nicely, and the fork seals leak.
Mainly - I'd like to know what to look more closely at... and to look out for (and fix), to bring it back to the great bike I have heard so much about. And - If any of you live in Calif, is there anything special I need to be aware of to go ride the KDX in a public riding area?
Thanks in advance-
Hulagun
:ride:
Thanks in advance-
Hulagun
:ride:
