I am attempting to replace the front wheel bearings on an 03 YZ250. Are there any tips or advice you can give to make the job easier? What is the best way to get the old bearings out? Any advice or procedures you can provide is appreciated.
I'm guessing you posted this thread for HELP, not insults......sheesh! If you bought the bike used, as I have in the past, owners manuals seem to get lost in the shuffle. Although my wheel bearing techniques are blue-collar, they work.
Be sure to remove cir-clips. I use an old socket extention to tap the old bearings out in a circular motion (inside...out). Make sure to pop seals off new bearings (they're very stingy with grease), I use Bel-Ray waterproof, then replace seals. Tap bearings into place evenly and gently with a socket just a hair smaller than outer diameter of bearing. Coat inside of dust seals with grease, and even some grease on wheel spacers (to help hold them in while installing wheel), and a coat of grease on axle to keep from freezing-up next time. As insurance, every time I change a tire, I pop seals I can get to off, and apply more grease to bearing, dust seals, spacers and axle. If you ride in water, mud, or sand a lot, even more often is good.
I take it you guys have history. None the less, 2 strokes' valuable advice is not in the "F@#%'in manual". How 'bout a little civility. With your advice, we wouldn't know which color wire to clip. Therefore, we'd be riding like
Ya, I was just messing around with him. We used to cruise this site a lot a few years back. I didn't know he was still posting here. I am happy to see that he got his bearings in, he has just promoted himself to 'bearing guy" within our circle of riding buddies....
See ya, I gotta call our "fork seal guy" to see if I can get a hand from him...
