Which Pro Circuit Pipe Should I Get?
WHICH PRO CIRCUIT PIPE SHOULD I GET?
Hey everyone, i'm Phil and i'm new on these forums! :cool:
But i won't bore you here, i'll get straight to the point. I have a 2001 model YZ 125 which i love, its set up for serious motocross. I'm just about to go and buy a racing exhaust system, and its come down to the Pro Circuit WORKS Pipe, or the Pro Circuit PLATINUM Pipe. (with the R304 Shorty Muffler.)
Both are kick ass pipes, however i want to know if there's a difference in performance between the two. I've heard that the WORKS Pipe is great for midrange and top-end, and that the PLATINUM is good for torque. But is this true? (So far i'm leaning towards the Platinum, only because it looks sweet with the nickle-plated finish. ;)
Anyway, any help would be greatly appreciated.
i got the platinum pipe with the shorty silencer on my bike also. there was a noticeable difference in power right when i bolted it on. its also strong i have crashed many times and havent dented it yet.
keep the stock silencer and get the platnum pipe, i use the same set up and it definatly helps with bottom end power.
Studboy
Thinks he can ride
Both pipes are the same. The only difference is the finish (Plated vs. Bare Metal).
You're a bit mixed up. The Platinum 2 pipe is (according to PC) tuned for more bottom end, and the Works and Platinum pipes are the same pipe but with bare metal and nickel plates finishes respectively.
You know, these manufacturers have websites with useful information...
