trucktramp
13
I recently picked up an 86 xr200 cheap for my g/f to ride. It was smoking pretty bad so I knew it needed a top end job. I haven't torn the motor down yet but I figure rings and valve job since after the last ride it wouldn't restart and has very low compression. I am thinking about putting a powroll 218cc stroker kit in it (so I can have fun on it too). Anyone know anything about them or have any suggestions to hot rod it (if that is even possible)?
KTM Pete
32
I installed a 218(or so) kit from Xr's Only in my son's '86 XR200. Siginificant power increase esp. bottom end. Definitely more fun to ride but harder to kickstart. No reliability problems, a little more vibration
cujet
826
Also, don't forget to change the cam chain. All of the older 200's I see need seem to need a new one. This one item can prevent all sorts of trouble down the road.
I did a modified 200 with a very high compression piston in a stock bore/stroke. I added a hot cam, valve springs, big carb, big exhaust. The bike ran very well and would top out over 80MPH. If I were to do it again, I would go for the bigger displacement on a stock cam, wich would result in the extra wheelie power I like so much. In other words, my setup was lacking in low end torque, but had plenty of top end.
Chris
placelast
1,298
Good year-solid playbike; came with (relatively) long-travel suspension, zerk fittings, lights, and an odo.
My oldest son's first man-bike was a '96 (essential similar to yours). When he grew I put the above on it off of an '85 (blown motor) and we got even more time on it/life out of it. The thing slightly better ran well with little attention like opening the airbox, hi-flo airfilter, and rejetting.
Only thing I did not like about it was the odd 17" rear wheel and tall hump-back tank typical of pre-YZWRRMFKXFCRFX strokers. A seat upholsterer did a tall foam job for it and that helped.
Put RT gold valves in the forks for neo-cartridge action. Four Strokes Only sells a muffler insert (from another bike) which opens up the exhaust but it remained relatively quiet.
