_JOE_ said:The engine and tranny share oil. If you filled the engine with oil you also filled the tranny. Check your clutch lever free play.
OK... the OEM parts list picture for the shift drum didn't come through. Makes my reply useless. So... go to rocky mountain atv/mc / Honda OEM parts / '91 XR200r / shift drum and you will see the above listed parts.99% sure part #6 is worn. Buy #6 and #10 to fix your shifting problems... It is an easy fix
