So far does anyone have any basic clicker settups that I could use to start my testing ? its a 2001 cr 125 stock suspension. 165lbs with gear, 5'11" tracks are hard pack & fast
Im no Einstein...But I might be a rocket scientist.
Im a similar weight to you so this may suit you as well.Take off the shims that sit on the base of the compression stack.They are the ones below the 2 thick washers.Replace with another 2 thick washers.Then set the oil height to the minimum recommended in the manual.Then set the clickers to the same as the manual.If you dont remove the shims set the oil height to the minimum again and run the comp adjuster at full soft.The shock cannot be adjusted so as to stop the kicking under breaking-it needs revalving.My best setting was to decrease low speed comp by 5 clicks but if i lessened High speed it made the kick worse.
[This message has been edited by marcusgunby (edited 04-12-2001).]
