Hello Folks,
My 94 KDX has always been a one- to-two kick bike and no problems. However, right now I can't seem to get a spark. The bike had gotten real wet (hosed it down) but now won't start (i did have a little mosture under the ignition cover when I removed it, and attempted to dry it out with a small heat gun:eek: ). I've change the plug and dryed everything off and changed the plug but no spark. I've now pulled the flywheel and removed the stator coil, my questions are:
A) how often does a stator go bad? could I have damaged it with the heat?
B) how can I test it?
C) what are other common causes of no spark that I should check?
thanks in advance,
WoodChuck
thanks in advance,
WoodChuck
