r.2 stroke
- Dec 29, 2001
- 73
- 0
Hi,I dont know if this is normal or not,but when i snick it into 1st gear with the clutch lever pulled in hard to the bar,it makes a good clunk,and the bike wants to edge forwards...kind of more than i remember it used to when it was new.The other thing is that when the motor is off,and the bike in 1st gear,there is no way you can roll it frorward or backward with the clutch lever pulled in hard to the bars again(hot or cold).I have the correct amount of lever end play,the acuating arm on top of the clutch cover is between the 80/90 degrees as stated in the manual,gear oil always fresh,and pulled the clutch basket out to have a look....really no grooves on the clutch basket fingers to speak of at all,i cant compare what the steel and fibre plates should look like,but they appear ok.its an 07 kdx 200 with not alot of hours on it,maybe 200hrs max.If every else has the same characteristics with their clutch,and i hope so..then sweet!!if not,what should i be looking for.....
Roger.
Roger.
