I really messed up and snapped the Clutch cable guide (both sides) that hold the clutch cable to the crank case... Right where the cable meets the clutch lever above the sproket... What a bone-headed move on my part. I was trying to replace my clutch cable and stepped on the cable by mistake, snapping off the two sides of the retaining guide off the crank case.... Anyhow, can these be welded in place or is their a glue that will hold diecast aluminum??? I assume if it can be welded the whole crank has to come apart? If anyone has any suggestions or methods to fix this problem please let me know ASAP. I am tryin to avoid pullling the engine apart but, if that the only way... Please give me your thoughts... Thanks
