rebuilding a crankshaft is not a major task. Any shop should be able to do it for $45-$65 plus parts. All they do is press it apart, reassemble the parts, press it together to set the rod side clearance and align the centerline's of the bearing axles. If you have a crank fixture all you do is set the s/c because the centerlines are already set
