Engine-Differences btw. 380 SX AND 380 EXC/EGS ?
Ivan K
11
hello friends !
in the 380-manual they say that the SX has a different Ignition, and the gearing is also a little bit different, also the jetting.
are there any known differences which they DONT tell in the manual ?
for example, is the porting little different ? or is there a different compression-ratio ?
Am I right that the stock-380-SX has 65HP and the EXC/EGS has 60HP ?
i startet wondering about this topic as i heard that some guys said that the 520 SX (4stroke) and the 520 EXC (4stroke) are 2 completely different bikes compared to each other in the performance of the engine. ("SX has the more agressive engine")
thx for any information, sorry for my bad english
cujet
826
5
I am sorry I do not know the actual in's and outs of each engine. However I believe the HP numbers you quote are slightly suspect. The 380EXC was producing around 45-48 RWHP. There may be a slightly different output between the bikes due to the silencers.
Chris
Ivan K
11
hi !
thx for answering
we had different 380´s on a dyno...EGS and EXC...both produced about 54 RWHP
60 RWHP were reached by some of my friends after putting on a aftermarket pipe and some other modifications
those 60 HP from the manual are on the clutch
also we never had the chance to compare a SX barrel to an EXC/EGS barrel...no one here owns an SX :-(
for that reason we never had an SX on a dyno :-(
cu
Ivan
Ivan K
11
read this (in german) :-))))) just to let you know where my infos are from
KTM 380 SX
Motor: Einzylinder 2-Takt, Außlaßsteuerung; hydraulische Ölbadkupplung
Hubraum: 368 ccm, Bohrung/Hub 78x77 mm Getriebe: 5 Gang
Zündanlage: Kokusan Digital 2K-1 Starter: Kickstarter
Vergaser: Keihin PWK 38 Leistung: 64 PS bei 8200 U/min <----------
Fahrwerk: Zentralrohrahmen aus Chrom-Molybdän
Gabel: WP USD 43 MA Federweg v/h: 295/320 mm Dämpfer: WP PDS
Bremse vorne: Brembo 260mm Bremse hinten: Brembo 220 mm
Reifen vorne: Bridgestone 80/100-21" Reifen hinten: Bridgestone 110/90-19"
Tankinhalt: 7,5 Liter Sekundär-Übersetzung: 14/50
Sitzhöhe: 925 mm Bodenfreiheit: 385 mm Gewicht: ca. 101 kg
PS means HP !!
KTM EXC 380
Zündanlage: Kokusan 2K-3 Starter: Kickstarter
Vergaser: Keihin PWK 38 Leistung: 60 PS bei 8200 U/min <---------
Gabel: WP USD 43 MAFederweg v/h: 295/320 mm Dämpfer: WP PDS
Reifen vorne: Bridgestone 90/90-21" Reifen hinten: Bridgestone 140/80-18"
Tankinhalt: 9,5 Liter Sekundär-Übersetzung: 14/50
Sitzhöhe: 925 mm Bodenfreiheit: 385 mm Gewicht: ca. 109 kg
PS means HP !!!
