The Honda Pilot
- Feb 25, 2001
- 394
- 1
- Thread starter
- #26
So your saying I will have to floor it to haul my 4,000-6,000 pound loads ? I dont even have to floor it with my 4.2 ltr. small v-6 ?
That is very normal for all diesel engines. Remember to shut down a diesel, you essentially have to cut the fuel off. The governor goes to zero rack andl the pump stops delivering fuel. Due to injector balance, some cylinders are still being supplied a small amount of fuel while others are not. Essentially it's mis-firing (shakes like it's not running on all the cylinders) until the pump shuts fuel delivery off.Originally posted by The Honda Pilot
... the only thing that scares me is when I turn off the motor the truck kinda rumbles and shakes...is that normal with it being a big v-8 ?
Not totally familiar with the Navistar design. I assume you mean this engine used a pre-combustion chamber.Originally posted by Highbeam
... and it used indirect injection.
Gasoline must atomize with the air coming into the cylinder. If it is not properly atomized, the gasoline will "wash" the lubrication from the cylinder walls. You do not have this problem with a diesel engine since ignition begins the instant fuel is injected into the cylinder (or pre-combustion chamber). Diesel fuel is also not as refined as gasoline and closer to the crude base stock. A diesel engine will run (runaway) on it's own lube oil. :eek:Diesels are so cool. I wonder why the gassers don't use a direct injection instead of injecting fuel behind the intake valve. Multistage injection of a gasser would allow for a longer power stroke and yield higher torque.
One word CUMMINS.
To any fellow Diesel owner what kinda of RPM's are you turning over when you are traveling from speeds of 65-80 Mph ? My motor at 70 is turning 2 & a quarter thousand RPM's which isnt much for a gasser but
