I have just about given up, this is a plea for help.
I have a 2009 Husaberg FE450. When the bike runs it runs great. Unfortunately, it is not running. It starts and runs for about 5 seconds then shuts down. It seems the computer cuts the power.
Here is what I have done to help diagnose/fix the problem
- Installed new battery
- Bypassed the roll over sensor
- New spark plug
- Ripped the entire wiring harness apart looking for breaks/shorts
- Tested every sensor per the repair manual, all are well within spec for voltage/resistance/continuity
- Checked fuel pump pressure, it‘s +40PSI, FUEL PUMP IS WORKING, all filters are clean
- No error codes are being thrown
I had other issues. Previously, bike would run great for about 1.5hrs, then start bogging, stall and finally not start again. It has left me stranded a few times this way. I thought I had the problem fixed, but happened again last weekend. The Berg fairies didn’t fix it this time, which in a way is good, because when I fix the problem this time, it should be fixed.
I am at the point where I don’t know what to do next. Everything simply tests fine but bike won’t run.
Any ideas? I need this fixed, I have missed a couple races already this season.
- New spark plug
