Kawidude
D'oh!
1,386
I know the popular opinion is that IE is a pile of junk. It is, however, the only program that seems to allow me to download attachments from e-mails and ftp sites exactly the way I want to. For some reason every time I open IE it tells me it cannot find my server. The only way I can get online is to use Netscape Aggrivator (which won't allow me to download attachments properly).
In IE I go into Internet Options and click on connections. Under Dial-Up and VPN settings it says Broadband Connection (default). Under that it is checked to "Always dial my default connection." When I click on the LAN settings it is checked to "Automatically Detect Settings."
When I try to navigate to a web page it says, "The web page you requested is not available offline. To View this page, click Connect."
It never used to ask me to connect. I'm connected to a Cable modem and it was always just connected when I went on-line. It has been this way for over a month and I can't figure out what the problem is. I obviously don't understand much about this feature, so if anyone has a quick bone-head tip for me that might help, I'd certainly appreciate it. I just can't figure out why it will let me look around offline but won't give me total access to everything without asking me to connect (which doesn't work either). Thanks in advance for any tips!
trial_07
Play with gravity
1,430
Which version of IE are you using? Did you play with anything before it started doing the problem?
Kawidude
D'oh!
1,386
It's version 6.0. I hadn't done anything to it before it stopped working. Interestingly enough, the same thing happened to my laptop's IE about a week later. Too weird. I'm wondering if an un-install and then re-install of the newer version might solve the problem.
trial_07
Play with gravity
1,430
I run version 7 which has greatly improved from version 6. Hmmm...Verify if the Work Offline is checked. Sometimes we tend to overlook the obvious stuff.
Okiewan
Admin
2,238
Texas
LOL.. good luck trying to uninstall IE, Bill was sued over that. "It's an intergral part of the Operating System". Riiiiight.
Is there anything in the lan settings about a proxy server?
trial_07
Play with gravity
1,430
My IE appears in the software list. Yours may appear only in the windows component list. It's pretty easy to uninstall. Try installing version 7, it will erase the 6.
ellandoh
dismount art student
2,958
mine is checked to never dial a connection, thats for dial up i believe
Kawidude
D'oh!
1,386
Too funny!
Under the LAN section it says, "Use a proxy server for your LAN." But it's not checked.
trial_07
Play with gravity
1,430
So everything works for you now?
IndyMX
Crash Test Dummy
5,548
Amo, IN
Kawidude said:
Too funny!
Do you have a proxy server?
And uncheck "Always dial my default connection" like ellandoh said, thats only for dialup connections.
Kawidude
D'oh!
1,386
Nope. I set it to "never dial a connection." I can navigate to other sites but the same message keeps popping up saying that the page isn't available offline and I need to connect.
ellandoh
2,958
i usually keep screwing around for a few hours til im distraught then system restore is usually my savior :)
trial_07
Play with gravity
1,430
Is your Work Offline checked?
IndyMX
Crash Test Dummy
5,548
Amo, IN
AAAACKKK!!!!
I would never ever do that. I have way too much sh!t installed... I can barely keep track of it as it is.. Then to have to reinstall it all.. No way pal. :whoa:
ellandoh
2,958
IndyYZ85 said:
AAAACKKK!!!!
it doesnt get rid of everything , not even files, just installed programs after the date you pick to go back to
IndyMX
Crash Test Dummy
5,548
Amo, IN
Well, I don't have restore points anyway.. Don't trust em. I'm sorta old school.
Kawidude
D'oh!
1,386
Where would I find that? I poked around and couldn't find it.
trial_07
Play with gravity
1,430
I think it's File --> Work Offline for your version, but I'm not completely sure. It is Tools --> Work Offline for version 7, you might want to look there also. Hope this helps!
ellandoh
2,958
click on file and look at the bottom of that list
Kawidude
D'oh!
1,386
It feels like we're getting close. I looked and "Work Offline" was checked. So I unchecked it and now it's telling me it can't find my server again. I'm stumped.
kmccune
2-Strokes forever
2,726
Just install firefox and don't worry about it.
Kawidude
D'oh!
1,386
I tried that too. Firefox ran great for about a month. Then it told me I needed to download an update. It updated and hasn't been able to connect to my server since then. I have no clue what's going on. I liked Firefox except it didn't allow me to download attachments from e-mails and ftp sites the way I wanted to. I may have been able to figure out a way to change that, but I never got the chance to try it.
