Is a revalved '04kx250 suspesion better than '03?
G92Joe
202
A heard a few 04kx250 owners had preferred the stock 03kx250 rear suspension over the 04. Did anyone revalve their 04 to a better performance level than the 03?
fatherturtle
65
Not sure on the 04 set up but I know that my 03 rear suspension was pretty good. If it has the same as the 03 front end I would defenitly get it revalved. I weigh 190 punds and I had my compression on the turned almost(3 clicks out) all the way in. I hope I helped out some.
elf
695
The 04 Kawi had some changes. The shock linkage was changed the swing arm is longer and the forks have different internals. I am sure a good suspension tuner can get the 04 stuff working better than a stock 03.
Steve47
103
I'm still struggling with my 04 suspension. My suspension guy will do it again tonight, I think we went too stiff.
Bottom line, I'm still not even close to the 03 suspension but we will get there.
The motor of the 04 is so much better.
