Have any of you insane, out of control, money spending 50 nuts upgraded your front forks yet?
I have done the usual upgrade to the Applied stiffer front and rear spring, but the Front is still way harsh or we are just jumping larger stuff that it can't handle.
I have looked at the BBR front fork setup, fast 50's forks and some others...The aftermarkets look the way to go since buying new XR70 forks is not cost effective.
I was planning on doing the front forks while adding an I-Shock to the rear with an upgraded swingarm. Should Beefier wheel spokes be added as well?
Also, Classic Honda sells an Auto Clutch set, has anyone used this as well. I have an 88cc big bore on a '00 50, obviously replacing the springs and plates is cheaper, but do they wear faster?
Theres got to be a point where you dont have to spend any more money on these bikes, right?
