01RM250K3
34
hi i was just wondering where i can buy an aftermarket CDI for a 2001 RM250 because i cant find any aftermarket CDI for my bike all i can find is an oe cdi but thats for $367 and i dont want to spend that much. also i was wondering if my cdi is my main problem on my bike because it wont start very easy, it takes about 11 to 30 kicks to get it started and i got compression, fuel, and spark its just that i think the spark is pretty weak, i checked all my electrical with an ohm meter and everything was within specs except the cdi was very low, i thought it was an easy fix like the spark plug wire but i replaced that with a ngk spark plug wire and it still has trouble starting and i have my carb jetted properly and every other time i start my bike my plug fouls out and i just replaced the reeds a couple of months ago, so do you guys think my cdi could just be the problem?
RM_guy
Moderator
7,060
214
North East USA
Are the reeds OK? They should seal with no gaps or fraying. That's normally the reason for hard starting.
01RM250K3
34
when i first bought my bike about a year ago it would start just fine but it would still foul the plug, and now everytime i ride i it is getting progressively worse in terms of starting and fouling the plug so i dont know what it could be besides the CDI because when i check the spark plug for spark it is a very weak spark where you can barely see it so do you think its the cdi because the coil and the stator are to specs?
01RM250K3
34
im also running a ngk br8es spark plug so do you guys think i should go with a hotter plug to resist the fouling and if so which spark plug should i buy, also its gapped at 20 thousandths so do you think i should gap it bigger to like 30 or 40 thousandths to get a more intense spark?
01RM250K3
34
nevermind i wont need a cdi al least for now as all i had to do was adjust the float level on the carb it turns out it was out of spec by 9/16", now it runs better then the day i bought it, it starts on the 1st to third kick and doesn't foul my plugs up!
