silver_Truck
- Jan 3, 2006
- 4
- 0
Hey all, I've just finished rebuilding my 01 rm250 and getting the bottom end broken in (3 10 min on 20 min cooling heat cycles). I rode it yesterday just fine all though the clutch outer bolts backed out but that has since been fixed, the only other thing is that it won't idle. When I rent to ride it this morning it started up just fine on like the second kick and warmed up normally but when I went to take off to go ride it just bogged out and killed itself and now won't start, tries to but just won't catch. Actually it did catch once and just smoked a bunch and bogged down even if i gave it gas then it died after about 2-3 seconds. Any suggestions on where to start? Also does anyone have kind of baseline settings for the carb? It's got a fresh rebuild, suzuki piston kit, ims rod, all balls bearings and seals crank was trued, fresh maxima oil, redline premix at 36:1 92 octane, Twin air filter, ngk plug, moose torque reeds (the carbon fiber ones), pro circuit pipe and silencer ,if you need any more info to help me out I'll try and get it to you.
