PTCruiser
73
I'm looking for an inexpensive way to lower my seat height. I can drop the forks 1/2" but that will make the bike too squirrly. Can't I just add another 1/2" to my normal sag on the shock to bring things back into alignment and then use the clickers to balance things out?
Sage
dirtbike riding roadracer
Mar 28, 2001
621
Trim a 1/2" off the seat foam and re cover it, this works good on thick seats, not so good on MX seats.
Sage Wilkinson, KDX Link 1
[This message has been edited by Sage (edited 04-10-2001).]
Jeremy Wilkey
Owner, MX-Tech
Jan 28, 2000
1,453
PTC,
Id suggest you run a touch more sag and rasing the forks in the clamps over seat foam removal. If you must cut the foam be very sparing.
Regards,
Jer
"Danger is one thing but danger combined with long periods of suffering is quite another." Sir E. Hilary
wilkey@mx-tech.com
MX265
236
I have kind of the same issue. I own a 2001 KX250. It's great when I am on the bike. It fits me well and everything works the way it is supposed to. But when stopped, it's all toes from there(and that is on one side).At 5'6", maybe a KX100 would fit me better. :eek: Seriously, I have contemplated running more sag, but I keep hearing 95-105mm is a good range. I'm at 105mm. What would you truly consider to be a safe amount of maximum sag? On this bike, running the forks at the maximum height above the triple clamps is necessary on the tight tracks that I ride on, so the front end is OK.
[This message has been edited by MX265 (edited 04-18-2001).]
