Solid State
- Mar 9, 2001
- 492
- 0
Conclusion-
I did as complete analysis as I could with the three plungers I had (original, new Honda and MDK). All three are very different from each other. I also included the two weights in question (original and new Honda).
I could bore you with all the weights and measurements of each down to the milli-gram and micro-inch but I won't bore you any more than I already have (not sure anyone is listening anyway). If anyone wants data including pictures I can help.
I interviewed the Honda tech support rep and the MDK rep and decided to use the new weight and the MDK pin as I originally intended. It's scary how little knowledge is known with these matters. The MDK mechanical engineer quit without documenting the design to the folks that answer technical questions and the Honda tech folks know nothing really technical. He did ask me how I got the parts and his phone number though.
The installation was simple. I did not like tightening the cam cap bolts to just 10 lbs but I did (after using engine oil on the threads as required). The bike fired up on the fourth kick after four priming strokes with the kill button pressed. Those of you who care, the tank was emptied for over a week (after sitting idle for months) and I did not have to pressurize the fuel line with the $100 'tool'. I did, however, use the Honda cam chain tensioner tool for the cam chain. That was sweet but perhaps the trick is a manual tensioner in the end. I havn't seen one that I would buy yet.
Anyway, bike runs great. I set the idle to my calibrated 1800 RPM ear. Hopefully there won't be a problem since the repair probably won't be guaranteed by anyone. The price you pay for doing it yourself I guess.
Hope this has been helpful to you.
