Ok, I done a search but I dunno if I just didn't know what terms to type in or if there wasn't any threads about it, but I have managed to pull the cap off of my plug wire. My bike (99 YZ 250) went ALL SUMMER on one plug, never fouled, then all of a sudden about a month ago I couldn't get it started. I figured it was my fault like I accidentally pulled the throttle open while kicking, so I put a plug in. Started but it was in the garage so I cut it off immediately and then I couldn't start it after that. Tried another plug a few days later, it wouldn't start, plug was soaked in gas. Another plug, same thing, another plug, finally fired but again I didn't expect it to start so it was in my storage building so I killed it and rolled it out and then I couldn't start it then. 2 more plugs was wasted yesterday, both soaked in gas when I pulled them.
So I was trying to check for spark when I somehow pulled my plug wire end off of the wire. I looked down in there and it looks like a screw inside with threads and stuff, but was all brown and kind of rusty. So is that how it goes back on (although I'm going to get a new one I guess), just screw it on the plug wire and the "screw" inside goes up in the wire and makes a connection? I'd never seen a plug wire like that so I just thought it was kind of wierd. I assumed since the other end of the wire was hardwired into the coil that I just had to buy the whole assembly and couldn't even get an end cap until I started looking around on Yamaha's parts catalog.
