RECENT POSTS
02 YZ250 P/V Install ?
Studboy
Thinks he can ride
I am putting the powervalves back into my 2002 YZ250.
I am confused as to what way the secondary P/V guides go???  Those are the ones on the edges of the main P/V rod that open the secondary P/V's???
I have a  shop manual for the bike,  and if I put it in the way that it shows, it doesn't open the secondarys when the rod is pulled.  If I put them in the other way it doesn't seem right either.
Are the secondarys supposed to open on exhaust pressure or what?
I am confused!!!
Thanks guys! (And girls.) :)
The sub ports open up after the main valve. You have to rotate the actuator a little further to get the sub ports to open. On mine, there's quite a bit of resistance after the main valve opens because you're working against the spring between the main power valve and the actuator arm.
Studboy
Thinks he can ride
Thanks!!! That's what I figured after I got to really looking at it. It is a bit different than my KX, and after I looked at that it all "clicked".
