YZ165 said:I used a renthal non-o-ring on my new YZ450(selling dealer talked me into it,"It's the BEST"), streched on first ride, adjusted, streched on second ride, now it's in the trash! So you lose a hp or two, I can't use all the power this bike has anyway! :thumb:
Jaybird said:Show me a person who has problems with their chains and sprockets and I'll show you someone who missed at least one point of proper chain/sprocket care.
Jay, Have you run this test with maintenance to the ring chain? I mean lube it at the same frequency that you are lubing the non ring chain? You know some of us do lube O-ring type chains which I can only believe will make them last longer than your test of a non lubricated O'ring. What does the graph look like then? Got to be fair here.Jaybird said:On a test bench, as these tests are run, if the standard chain is given periodic lubrication thoughout the test, it will last longer than the ring chain.
There is a point in time when the ring chain will have consumed it's lubricant leaving nothing but soap base in between the rings. At this point the ring chain will make a sharp rise up the graph to it's death.
The standard chain that is being lubricated periodically will in fact last longer because it will not see a period throughout the test when it does not have lubricant protecting the friction surfaces.
MikeT said:It would be an interesting test don't you think?
I sold my 125 that had an O-Ring on it and I lubed it with your stuff. The chain was perfect even until I sold it. I bet if you performed that test, the lubed O-Ring would do pretty well.
BTW Jay, I love your signature. Wish I would have thought of it.
I use a combination of Jay's stuff and Honda (in the RED can) dry chain lube.cr2504life said:What exactly is your stuff. Right now im using maxima chain wax on a non o ring. Is this a good lube?
